I understand. I would like to make these. I have made several Batarangs very recently with much success. I’m cutting these out of old worn out saw blades from the woodshop. The problem I’m having with the regular tip is that there seems to be a lot of slack. I’ve tried adjusting the amps and speeds, but it doesn’t seem to help. There always seems to be a lot. It would be much quicker to deburr the edges if I could get a cleaner cut, which I think the fine cut will help with.
I would like to try out the fine cut nozzle before I decide to purchase one. Would it be okay to use for a few cuts? Once finished, I will buy my own set.
Thanks
NP
