There 2 that are the main culprit so if looking at the machine cartridge #1 being on you’re left goin 123456
7891011
Etc etc it’s #9 and # 15
Edit have we every considered the idea of wrapping all threads with plumbers tape(ptfe tape)? And if that would pose any risk, ie getting sucked into the machine and any other potential damage concerns that way they’d stick Bette and prevent misthreading
Chris,
are you saying the fielder is down?
There are 4 Phillips screws that hold the tread cones in for each filter… the cones should be replaced…
No cartridge from machine, so I just screwed them back in but when you go to take the bin out they’ve fallen down the last couple of times
@got_tools Best I could tell The cones are sealed in from the top compartment and that’s not serviceable.
We have not talked about taping the cones. Have you tried changing which filters are on the cones?
The new ones should be in “soon”. And they may have a better fit.
When Iooked at the treaded cones, what I was was serviceable from the filter compartment… we just need to see if we can order them from Felder
No just because they’re 4th and third row back and there’s a lot of build up so I literally had to crawl underneath so and slight disturbance and I would have taken a dust shower so I just carefully screwed them back in! I knocked a majority of the build up
Off but there was still enough to make me look like a snickerdoodle cookie so I was warry lol
Edit 2nd and 3rd
And I didn’t want to unscrew the 10 I would have had to to make sure when I was screwing it back on it didn’t crossthread it and end up ruining it
