Hello. Saw the yellow light on the felder.
Emptied the bins that were full. The yellow light came back again after some use. Any guidance will be appreciated.
@IanLee?
I opened the panels and used the air to clean the filter and will try again
The manual is in the file cabinet drawer in the annex. Depends on how fast it’s blinking if I remember right.
Noticed this today. It seems to be having problems when more than two or three blast gates are open. Closing the unused blast gates seems to clear the yellow light. This leads me to believe that we seem to have a leak. The yellow light does not blink, it comes on steady. Yesterday and today I have been turning the Felder off and turning the little black & white switch to the left two clicks.
As I mentioned in a previous thread and was chastised for, the fine particle dust from particle board clogs and basically makes the paper filters so coated in the resin and small particles and with the heat generate from the Machine it kinda cakes it on there so no air flow can get through
That wouldn’t make sense, the yellow light is an indicator of too much vacuum meaning the motor sucking in air isn’t getting enough so the issue is internally, think of it like putting a sponge at the bottom of a glass of water, and trying to drink, or drinking a really think smoothie, that suction that makes your cheeks pull inward is what the yellow light is indicating
The cleaning with the compressed air did the trick. The light didn’t come back on. Thanks to the video link on the machine i dared to open it and clean it.
