After pulling the engine from my Mini and getting it split for teardown, I’d like to get an adapter made up for mounting the block to the stand. The adapter shown below is considered by many in the Mini community to be the best at rotating around the geometric center of the block. I figure I can get the plates drawn up and exported for the dynatorch, but I’m not sure where to source plate that thick and in such small quantities, nor the thicker/shorter pipe section needed.
Where would I get the steel for this project? If I can get it cut, I’m sure it wouldn’t be too difficult to get it welded up.
