In case anybody missed it, I’ve been working on swapping the engine in the silver 200SX in the automotive square. It’s pretty close to completion, it just needs some finishing work and some fabrication.
Among the list of things that need to be worked out is the A/C compresor mounting bracket. Since the car’s A/C works and the system contains a full charge of rare, expensive, and difficult to replace R12 refrigerant, I’d really like to keep the system intact and installed. However, while the original bracket will bolt onto the new engine, its position puts its tensioner pulley in contact with the crankshaft pulley. Extending the pulley mount was an idea, but the bracket is made of cast iron and I don’t believe it will take well to welding. The position it places the belt drive for the compressor is also less than optimal. (The engine uses a 3-belt design to run its accessories, and the original bracket would require the compressor to be operated on the power steering/water pump/fan drive belt, rather than its own belt, as intended by the engineers)
I’m not very skilled in the arts and sciences of metalworking, so I’m looking for some advice here. Would it be feasible to fabricate a new bracket from sheet steel? (Not really this group’s area) Alternatively, what level of cost and difficulty would I be looking at in milling a bracket from a block of some sort of metal? (Totally this group’s area)
The bracket in question is pictured in the diagram below. It bolts to the engine block in 4 places, and the A/C compressor bolts to it in 4 places. The tensioner is a screw-adjusted block that slides in a small channel and carries the pulley shaft. (Similar to the second image)
Any insights are much appreciated, as I’ve been pretty stumped on this one part of the build.
With all due respect,
Kris
