Is anyone aware of where to find/buy larger size – even a sheet of – non-scratch blue scotch-brite material (this, but larger: Scotch-Brite Non-Scratch Scrubber). It is essentially a nylon sponge.
I can find 10"x4.5", but would really like at least 10"x12" or a bit larger. I’d rather not try and piece or glue the smaller units together.
Also, I’ve looked at the large floor scrubbers…doable, but they are really too thick for my purpose. And I’ve seen longer rolls of standard thickness stuff, but they are not wide enough so I’d be back to gluing-up pieces. And my need is not enough to turn to Ali Baba (i.e. a hundred sq ft at a time).
I look into it. I was hoping to use a mat in sink as protection and drainage. They have silicon mats for this but I don;t like them as much as this option.
All I could find were the circular ones…thanks! I wish they were less thick, but beggars and choosers and all that. But these will probably fit the bill…I appreciate the hunting. :–)
Some HVAC filters use a similar, but somewhat less dense, material. They are available in sizes bigger than 20” square. Perhaps if you stripped off the cardboard wrapper they would serve your need?
A Google search found this example for about $10 (and no cardboard wrapper to remove). It is also explicitly washable, so would stand up to water.
Best part is I can stop by and actually look/feel. Product page indicates it’s made from polypropylene (rather than nylon for the scotch-brite scrubber), but since both are synthetic materials, it may not matter too much.
