Hello DMS Potters,
Please be sure to get your pottery items before they expire. We hate throwing away items you’ve spent time crafting. THIS POST IS NOTIFICATION THAT THE ITEMS LISTED HAVE BEEN DISCARDED, so please remember to check your projects. We hate throwing away items you’ve spent time crafting.
REMINDER
We allow 30 days for your clay item to be on the In-Progress Shelves.
**TIME LIMITS IN CERAMICS DEPARTMENT**
ITEMS ON BATS is 7 DAYS
Please try to return within 7 days to move your item from the bat to a board.
If a project is on DMS bats over 7 days, we will attempt to wire off your project
and place on a ware board. Thankfully, we have not had any issues with doing
this yet, but mishaps can happen.
ADDITIONAL RULES IN THE CERAMICS SPACE
- If you have a glaze that will run, please provide your own cookie before it goes in the kiln.
- If you have not allowed an unglazed bottom and a bottom edge of 1/4", please provide your own cookie.
- Bisqueware should not be stored on In-Progress shelves. If noted, you will have 7 days to remove it before it is discarded.
- If your project contains added items, like copper, toothpicks, or newspaper…the piece won’t be fired unless these items are removed. Basically, anything that might cause damage to or influence other pieces in the kiln will likely not be fired. Generally, these items are placed on the NEEDS ATTENTION shelf with a note.
- If you haven’t seen your item come out of the kiln, please check the NEEDS ATTENTION shelf near the kilns and check the Ceramics Kiln News thread.
