Can someone share an up-to-date copy of the expansion floor plan?
I’m going to use it as part of our new network cabling documentation.
Additionally a floorplan of the current 104 would be nice as well, so we can start documenting things better in the existing areas as well.
Cheers,
-Jim
EDIT: Additionally, I’m curious what expansion is currently using for floorplans and how they’ve tracked changes. Infra just procured LucidChart Enterprise for our networking documentation and it has floorplan support. One of the nice things it does is as you update documents, images etc you’ve embedded in wikis and other sources automagically update since they render a view based on the living document rather than static exports
The following is the current floorplan for the combined 102 and 104 space as it exists today. This floorplan is identical to that which has been filed with the City of Carrollton. The plans are being documented via the latest version of AutoCAD 2019 software. All updates for Sub-Contractor quotes, Building Permits, City Planning, and Fire Marshall are in this preferred format.
Print the page out, mark up your cabling information, and return a copy to me so I can update the official document. You will notice that the new proposed walls are not in this drawing. This is the current official version.
Makerspace Drawing.pdf (69.4 KB)
Drawing changes are being tracked as additional building permits are issued with the City of Carrollton.
Thanks!
So it’s enough to get started, but is there by chance a copy that has the committee locations in it? I know that some have moved around from the original doc I had.
EDIT: I also just noticed that document doesn’t have scales nor measurements.
-Jim
The only committee areas that have changed are the swap between Vector and Science.
Okay, then try printing these documents.
Drawing Lower Left.pdf (76.9 KB) Drawing Lower Right.pdf (77.2 KB) Drawing Main.pdf (166.8 KB) Drawing Upper Left.pdf (72.1 KB) Drawing Upper Right.pdf (74.5 KB)
Drawing Main.pdf is the full drawing with 5 foot squares overlayed. Note the comments in the lower left hand corner for the location coordinates that are being used. Bottom corner is S000E000 (effectively 0,0) and measurements are South and East from that point measured in feet. Example: The 104 Server Rack is located at S212E077, the 102 Server Rack is located at S102E082. That should get you within one foot of your location throughout the building.
For a larger print I have divided up the plot into 4 equal sections; Lower Left, Lower Right, Upper Left, and Upper Right. The pdf files are labeled accordingly. I hope this helps.
