Hello. I’d like to start this conversation here, and others can link to it if it should go under a different category. I’d like to see about expanding the use of the CNC router. I think a good addition to the toolbox would be a diamond drag engraving bit. Here is a link:
http://www.widgetworksunlimited.com/CNC_Diamond_Drag_Engraving_Bit_p/cnc-dmnd_engrv-250.htm
This addition would allow engraving on plastics and glass (for making lighted signs), brass, aluminum, steel, and granite. and before anyone freaks out - there is no mess generated. It works by literally scratching the surface with a diamond tip. Generating the toolpaths for this type of work would be done on the same vectric software VCarve (or Aspire in the future) already available on the jumpserver (and which I would be happy to teach how to use).
This would open up a lot of possibilities for people working in metal, creative arts, jewelry, and others such as glass. However the first discussion is whether the wood shop committee wants to open up the machine to anything other than wood. It would be a shame if they didn’t since the CNC is a flexible machine. Keep in mind no one will be ‘cutting’ metal, plastics, or glass. Only engraving (scratching) it with the spindle OFF.
Lastly - it may be easy to say this would best be served on either the Shapeko or the Emco. Except that the shapeko is currently out of commission and I don’t know anyone using or teaching how to use the Emco. In both of these two cases, there is the added burden of learning a more complicated CAD system vs. the existing base that already knows VCarve. And there is the added concern whether these tools have enough Z axis clearance. The bit is spring loaded, so it is a bit long.
I personally only use it on engraving some of my lighters. But here are a few possibilities.
ok, that’s my proposal. I’m already doing this at home on my own CNC so I’m personally not going to be affected if this is regected. But I would be a shame if it were since it is such a simple thing to implement. I’d really love to see more people doing this type of work and keeping the CNC busy. Cheers!
