As @procterc mentions, speed is important. As an example: Our Kalamazoo Cold Saw is designed for cutting steel. At high RPM the blade is turning at 60 RPM. I went to site to see what the Alum gearing would be (about 4 years ago). Switching the gears gave a blade rpm of 1,700! Almost 30 X. But that saw has coolant that cools and lubricates the blade.
Gullets size is generally larger since the chips are bigger and have enough room to curl and fall out without sticking - that why on Bridgeport we use 2 flute cutters so there’s more room for the chip to clear.
Since we don’t run coolant on that saw, we should have “Air Gun” chip blower that gets down to an advertised -20 degrees. Alan and I fooled around with one night, the lowest temp we were able to get was -19! In a very narrow band of the air stream stream. No moving parts, just compressed air. It swirls it around inside, and there’s some sort vortex that separates the air into one side cold the exhaust side was around 140 degrees. Intellectually I get what’s happening, but it also makes me believe that magic exists.
It might be worth trying.
