Hello. I am trying to use Evo saw. Code I was given for lock does not seem to work…has it been changed recently? barring that, is it possible it needs to be reset, i.e. I am not starting in the middle of someone else’s failed attempt?
I had a similar issue last night.
Is there a way to reset lock so I know I am starting from “1”
I used it last night, lock code is the same, sometimes it gets stuck. You have to press the u beam into the main body twice to clear it.
That did it…thanks.
