Engraving a laptop case
I have a couple of laptops that I want to engrave, but have a couple of questions before I risk damaging them.
  1. How do you determine settings since you don’t have a ‘test piece’
  2. Are there any laptops whose case materials shouldn’t be used?
  3. If yes to #2, how do you tell?
  4. Any suggested starting point for settings? (FSL)
I know the DMS laptops were engraved, and I have seen others so I presume this is doable.
@LisaSelk came up with the file and settings used for engraving the DMS laptops, maybe she could help?
Metal laptops (like Macs) would fall into the “do not engrave” bucket unless you have the correct pre-laser coating treatment for them.
Pop the plastics off &try on the inside first?
