Do we have any kind of press that I could use if I wanted to emboss some paper?
Will 50 tons be enough?
How big is object? There are several arbor presses around that could be adapted. from small used with leather to the 20 ton in Machine Shop. But if you really need to get after it … there is a 50 ton press.
Careful that paper may leave an emboss on the 50 ton plate…lol
True, on the 50lb press please limit it to no more than two sheets of 20lb stock.
With a stencil the rolling mill be work
That’s a good idea, but I had a larger item in mind.
I wonder about Cricut.cameo machine in CA
I still want a class on this machine only been asking for months
