Is there something in dynatorch that has to be enabled for THC to work? I tried to cut some stock that tapered, but the z height did not auto adjust and caused the torch to get stuck on the higher sections. I’ve seen this torch cut corrugated material online. I know I’m missing something but cant find the right option. I did check to make sure that the lead was connected on the shield. It does seem quite loose but it is connected.
I saw on another post that it was found disabled, and they re-enabled before class, but it did not say how or what to check.
Thanks
