I’m not putting this into the Issues as the issue could be with the setup.
I’ve opened the gcode in the Sheetcam, set the material and do a dry run on the 3/16" aluminum. When I click the lightning bolt, the z axis motor will adjust the torch to where it hits the material and then it backs off slightly. It tries to establish an arc for 5 seconds before it pops up an error message. I’ve tried changing out consumables and moving the position around to no avail. I don’t have much experience on the machine. Is their something I’m overlooking?
Thanks for any suggestions…
