Came by to use the drum sander the other night and it didn’t have any sandpaper in it. I’m new to Makerspace so i didn’t know if the machine was down or it just needed new sandpaper. If it was the former, does anyone if its operational yet and if it’s the latter where do we keep the drum sander sand paper?
Thanks!
Sandpaper, if there is any, is in the cabinet on the backside of the drum sander. Pull the handle out and turn.
Be careful if you put the new paper on, it needs to be lined up correct and pulled tight the entire way around the drum. If you’re not sure how to do it, ask for help.
Sandpaper is usually in the storage cabinet for the drum sander.
