Do we have anything to pump out excess ATF?
I’m about a quart and a half over.
You should be able to take a tranny oil pump ($3 oversized soap dispenser thing) and hook it up backwards
May I suggest Turkey Baster, but only for non-food use.
Thought we had an extractor…
I’ve taken a 4" pvc with caps & a clean out on one end. I hooked a vacuum pump up to the pipe & pulled a vacuum. Used a piece of clear hose then stuck it down the full or dipstick tube to suck it out. The other end of the hose is hooked to the pipe with a valve & barb fitting. Very cheap to make.
That is a simple effective tool hack! If you don’t have a vacuum pump, you could rig up a shopvac for the suction.
I just dropped the pan, but thanks everyone for the input.
I did leave my fluid up there though and I’m just now realizing it : /
I’ll be back first thing in the morning to get it.
Was I the only one who thought, at first, this was mis-categorised and belonged in Hatchers?
Drain the swamp…
