I would like to machine a dovetail groove into either aluminum or a low-strength steel. Does the machine shop have a dovetail cutter that can cut this groove? If the image doesn’t attach, the groove is a 60-degree included angle, with an undercut depth (aka cutting width) of .101". The height of groove is .188". I’m thinking an Enco Model #367-0150 would do the trick (?).
Any thoughts or suggestions are appreciated.
Also, I would like to cut some aluminum wheels for a clock on the Haas. I would need some 3/32 mills to machine the profiles. Do we have a holder for this size of mills and 3/32" mills available?
Thanks for your help,
David
