I figured for smaller objects or things that need to be exactly centered, it wold be much easier to put the anchor point in the center of the vector cut. I checked the website and the manual but wasn’t able to find an adequate answer…
…also while I’m bothering people about the laser, I also haven’t found how to change mm to inches, thanks!
Oh man. I’m all ears if you figure out that mm to inches thing.
I ended up grabbing a piece of scrap, running the first couple of seconds of a cut on the scrap, then placing the piece over that spot, removing the scrap, and starting the job again. Finally got me what I needed.
It’s a good practice to be clear when asking about tools that we have more than one type of. As far as we know, he may be asking specifically about the Lasersaur, or he may be asking about all three of our printers - especially considering it was a multi-part question.
Speaking for myself, it has more to do the using the grid overlay on the GUI and guesstimating where a cut will begin. If you want it to be exact, it’s gonna be hard. But even getting close is hard if you’ve spent a lifetime measuring inches.
I have two questions re: Lasuersaur.
When the bed is heavy with debris, may I lift the grid and clean it?
Does anyone know the spacing on the grid? I’ll measure it next time I think about it, but it would be convenient if someone happened to know.
If your using RDWorks, the way to change the anchor point is with the “Config (S)” menu item, then click “System Setting” and you’ll see the heading “Laser Head” under which is a 3x3 matrix of radio buttons. Selecting the desired one will move the anchor point to the center, top left, whatever you want.
Thank you very much for this answer. I had compromised by homing the laser at 0X/0Y and cutting a target 2 X/Y of cutting area out to control the point for smaller items, but thats not really practical for anything much bigger.
