Does 3D Print Queue still work?
On the wiki there is mention of a webpage from where the print progress can be monitored. Is this webpage still functional?
https://dallasmakerspace.org/wiki/3D_Printers
Thanks.
sadly no, the webpage no longer works, sadly that website encouraged a lot of people to start a print and go home to sleep, which is against the rules. however if you are on the site, there is a number (url) on each printer that you can input for that octoprint.
Thank you for your reply. I am in the space now and I will go look for that.
Yes, I found it. Thanks very much.
No because the IP address changed or the site that was setup was moved with the servers. The other issue is the way that octoprint was setup, the cameras almost never work correctly, even if you’re on the network. I think that defeats having the Pi’s now. But the people that were working on the Pi’s disappeared and aren’t here to help fix it.
