The column was originally written by Martin Gardner, then picked up by A.K. Dewdney, and I believe now by Ian Stewart.
This was my second favorite column in the magazine growing up, after the Amateur Scientist column.
On Sunday, I was feeling lazy, so I browsed the web from my couch and came across a archive of some of these columns and similar material from old magazines. One that struck me was the concept of number palindromes. These are numbers that are identical when read forward or backway. As an example is 121
In one of these columns there was an algorithm that allows you to find such palindromes from any starting integer.
START:
Let A = starting integer
Let B = reverse of A
Let SUM = A + B
If SUM is not palindrome
A = SUM
GOTO START
ELSE
PRINT SUM
So if you start with 21
A = 21
B = 12
SUM = 33
33 is a palindrome
What surprised me is that when you start with most numbers you get a palindrome pretty quickly; however, 196 has not resulted in a palindrome ever after many thousands of interations of the above alogorithm. As @artg_dms likes to describe it this is a good nuero plasticity exercise…
Anyway here is a quick python implementation if you want to play with the idea.
import sys
def reverse(value):
tmp = str(value)
retVal = tmp[::-1]
return int(retVal)
value = input("What number do you want to try? ")
a = int(value)
notpalindrome = True
while notpalindrome:
b = reverse(a)
sum = a+b
if a == b:
notpalindrome = False
else:
print(a, "+", b, "=", sum)
a = sum
