Do we need a reading comprehension class?
Seriously? It’s written right there on the barrel…
OK, that pic worked… DUST AND CHIPS LESS THAN 2 INCHES ONLY…
I obviously need a class on how to post a pic…
Reading Comprehension is not the problem that needs fixing…
Anybody else just get super relieved when the pic of the nit excellent isn’t you lol? There have been blades and all kinda things in there the other day. We can cut thicker letters in vinyl?
Anything used for makerspace on the vinyl cutter is free. So absolutely yes. This goes for any committee area.
Lol ok I’ll try to run them this afternoon in whatever color we have the most of. I will not make it a Holy Hand Grenede thing even though I want to…
Awesome!
I think that would be cute
I’m guessing a lot of this is “the broken window effect” where people throwing away scrap see that there is already large pieces of scrap in the barrel and think it doesn’t matter.
O MAKER, bless this Thy wood barrel that with it Thou mayest lathe Thine wood to tiny bits, in Thy mercy." And the MAKER did grin and the people did sand upon the boards. And the COMITTEE spake, saying, "First shalt thou take out the scrap, then shalt thou measure two inches or less. Two inches shall be the number thou shalt measure, and the scrapping shalt be wood. Three shalt thou not measure, neither measure thou scraps not wood. Once the number two inches, being the acceptable measure, not exceeded, then lobbest thou wood scrap of DMS towards thy barrel, who being full in My sight, shall empty it.
I’m sure it’ll go over a treat lmao
Until we start naming-n-shaming and/or enforcing suspensions for this, and similar poor behaviour, don’t expect anything to change.
Waste of time, sadly. Speed limit signs don’t stop speeders…right?
How about a cover with two inch holes in it?
This particular one was really irritating because I and another member had just emptied that barrel about 2 hours prior. It was nearly empty. Which may be the reason - “hey empty trash can!”
In the past, I had thrown in larger pieces too. You are cutting and wanting to keep things tidey as you work, it’s easy to toss scrap into it, especially when it’s empty. I didn’t notice the message at first, but as soon as I noticed the sign, I pulled out the bigger pieces I had thrown in there. Newer folks are just not noticing the sign.
Not sure why it’s only for small scraps?
You know, I’m not sure either. I remember a similar rule from high school shop class. It may have something to do with walking up to a trash can with a dust pan full of sawdust and not having a place to dump it because all the trash cans are full of large scraps.
Our HS separates for the raku firing. Ok so grate with 2 in holes and more obvious letters (it doesn’t take long to run vinyl at all)
You are not getting it…
Nah I get it. Just trying to remove all excuses on case they end up deciding to put folks on blast in the future
To what end? Think about it…what happens around here when all excuses are removed?
I understand your heart is in the right place…
I don’t actually know. Lol I’ve never met a CA that can’t come up with a new excuse as fast as old ones are knocked down
Exactly. (except I am not sure what CA is in this context…Criminal Alien? Not sure? But other than that…exactly!)
Nothing happens to anyone because holding people accountable wouldn’t “Be Excellent” to some people’s mind.
Gedankenexperiment: put big day-glo radioactive 10 ft tall vinyl letters that also kick you in the crotch when you approach on all trash bins that say “do not fill past top/overflowing; empty into dumpster first!!!” What are you willing to bet that this has the intended effect, in general?
