Taking @Photomancer’s advice and breaking out each of the Hateful Eight into its own thread. Less for me to moderate. Let’s knock these out. Off the top of my head…@pinewoodnut, @talkers, @tomthm, @motopilot, @PearceDunlap, @merissa, @JoshW, @gbeauw, @somecallmery, @bpamplin, @BLOOM, @Kati .
https://dallasmakerspace.org/wiki/Laser_Cutter_Materials
Material: “Thick ( >1mm ) Polycarbonate/Lexan”
Danger!: “Cut very poorly, discolor, catch fire”
Cause/Consequence: “Polycarbonate is often found as flat, sheet material. The window of the laser cutter is made of Polycarbonate because polycarbonate strongly absorbs infrared radiation! This is the frequency of light the laser cutter uses to cut materials, so it is very ineffective at cutting polycarbonate. Polycarbonate is a poor choice for laser cutting.”
Question: is there even a reason to OK thinner sheets?
EDIT: Click “like” if original wording is still OK.
