I realize that there is a maintenance day this weekend- I hope to attend instead of just making suggestions for others. Luke and I inspected the Delta and where unable to address the height adjust issues. It got to the point where it appeared that we needed to remove the table top to get to the gear that we speculate is either worn out or just packed with years of grease, grime, and sawdust. Since neither of us where sure about this conclusion, we stopped; however, the issue has been on-going for numerous months.
If anyone has expertise with the Delta, I would be appreciative for either advice on how this needs to be serviced and/or for actual work. Currently it takes a ‘crazy’ amount of pressure to turn the wheel to adjust the blade height. This is far from ‘normal’ operation and I fear that ‘forcing’ the wheel is not a good idea; however, I watch people doing this on almost a daily basis. Last fall, cleaning the gears and spraying them helped for a few days, but now the issue doesn’t not seem to improve with normal cleaning and greasing.
The friction involved with the Delta is my number issue with the Delta, but if the Delta where to receive some ‘love’ the blade angle does not adjust to zero degrees. Although the Sawstop is a newer saw, some of us prefer the ‘old school’ Delta and the fact that it is our only saw with a Dado stack, it is my preferred table saw. It would be awesome if it could make the ‘list’ on ‘maintenance day’.
Thanks,
Joe King
