Delta Table Saw 1/26/16 6PM
The Delta Table saw is having issues and needs some TLC. I plan on starting around 6PM Greasing and fine tuning. If you want to learn how to do any maintenance on the Delta Table Saw tomorrow I recommend you come out. Wear crappy clothes as you will get dirty.
@AlexRhodes I am on my way there!
Table Saw is in a lot better shape. Everything has been greased and aligned. Thanks to all that came out.
If someone has the time the tops of the saws could use some paste wax. It is located under the woodshop bench with the turning plates.
Will we be replacing the missing knob on the height adjustment wheel on the Delta any time soon?
Not at this time. It’s not an essential part and expensive. Its all greased so it should move easier.
