I’m confused. These pieces were discussed at the committee meeting earlier this week. I was under the impression you were ok firing these in the time frame required with the needed presoak/candling time. You mentioned specifically during the meeting you would be running these with a presoak so I assumed there was no issue. If you had an issue doing these, I wish you would have discussed it with me during the meeting so we could clear up any concerns then.
I don’t see an issue with the turn around time I needed on these. Jason and I planned the timing of our classes together weeks ago. Our biggest constraints were coordinating our teaching availability plus allowing time for the pieces coming out of my glaze class to be finished and available by Christmas. We allowed as much time between the two classes as we could. We knew it would be close and were both comfortable the bowls would survive just fine and not be a danger to other pieces. We double checked this with Christy including her availability to prep and fire the pieces as well as the proposed modifications to our standard firing protocol these needed to go through. She didn’t see an issue with it either.
We were aware the firing time was going to be unusual for the way FA usually does things, however, it is not unheard of to safely do extremely quick turn arounds like this. It’s standard practice for some artisans, particularly high production ones. The pieces were checked on before the meeting and as expected, it was determined they were dry enough to fire with just the added presoak. They came out just fine. The glaze class went really well. Almost half the class was made up of polyhedral bowl students and I’m ecstatic they had the opportunity to participate. Thank you for getting the pieces fired for them.
I intend to offer the glaze basics class on a regular basis as my schedule allows. Chances are good a quick turn around for firing class pieces will be needed again. So yes, let’s absolutely put this on the agenda for the next meeting. In the meantime, how about we discuss this next time we’re both up at DMS? I’d love the opportunity to hear your concerns surrounding drying stage for firings and address those in person.
