Dallas Makerspace Show & Tell - October 2019
Another couple projects and I’ll be ready for teaching sign off I think :grin:
A lathe handle I made. I turned the receiver on the metal lathe and milled the set screws. I turned the handle on the wood lathe. All from stock.
Very nicely done.
Completed bags by students in my Zipper Bag class tonight. Great job everyone! We had a fun time.
Cindy
A little line work. CNC carved. 4x5" in mesquite.
create everyday.
Thanks to @tomthm and Science, I was able to silver a microscope slide to make a rear-surface mirror (with hanging wire) for my vintage kitchen scene.
I routed the moulding and carved the “shell”.
We learned some useful things trying to silver the slide.
  1. The silver film wipes off if you touch it, even gently. I lacquered the silver film which was the back side of the mirror.
  2. You have to be fast. The silver precipitates out of the solution quickly. Even if you have enough solution left over to do a second item, you won’t have enough time.
Glass and mirror thickness is a problem in miniature. Standard glass is 1/8" thick which would be comparable to 1.5" in 1:12 scale. A microscope slide isn’t accurate either, but it’s a lot better and in this case, the thickness is hidden by the frame.
haven’t done this in a while, but here are a couple of leather embossing stamps I made for some old customers. Laser engraved on Delrin. 1.25"
IMG_2512
create everyday
I wonder if an old CD could be cut down?
I believe they are 1 mm thick which would make them about 1/2" scaled.
Optical discs are primarily polycarbonate so the Shapeoko seems a good choice. Which could also be used to shave the thickness.
However, they are actually translucent so more “mirror like” than “mirror”.
In any case, @John_Marlow, I have some old unburned CDs if you’re interested.
WIP, Halo Gravity Hammer
