Started yesterday with my turners cube. Yesterday was just cutting the 2" solid aluminum round stock to about 1.5". Then facing off both ends. Today I started squaring it all up.
They are down to nominal size, not quite a cube but close. My finished passes on it, I will use brass shim stock to keep from marring the final finish. This was all done on the lathe, no other machines. When it’s done there will be several cubes inside it.
how do I take this class?
This post was flagged by the community and is temporarily hidden.
Thank you @kyrithia for a great wire wrapping class. Here is the first part of bracelet we made in class. I still need to finish adding some wrapping in the split, but it already looks like an actual bracelet.
Also, thanks to the new 1.5" button maker, my wife made 102 buttons last night for a work event.
Your comment. Perhaps rethinking before hitting send to check for appropriateness would be a good idea. Thank you for doing so next time.
We had a wire bracelet class last night (lots of fun, amazing how folks picked stuff up!) and this was the sample I made for it earlier this week:
And then below, the one I made as the demo during class, I decided to do a mix of gold-filled and sterling silver…I’ve done plenty of those, mixed in some kind of pattern, but had a sudden Why Not, and grouped the wires totally half and half. Okay. That was interesting, liked it.
Then I started the part of the demo of how to do final step of attaching beads, then folks either hung around to finish or left to do it later.
And I kept staring at that strongly mixed metal bracelet…then had an idea to adapt another viney swirly thing I do elsewhere but haven’t ever on bracelet tops, used couple wires of different sizes vined around each other…so after class was over, I cut off the beads I had started, then did this instead:
I like it a lot, something new, and will be adding it to repertoire. And I’m having some other ideas trailing off of this I’m about to chase…
I made more decoden. This one is going to be for my daughter who likes pink but also likes zombies. I hope there will be another class because this is incredibly addictive.
Whelp, Unfortunately my white vase with lid was to heavy to enter into the Texas State Fair.
Fortunately I had a lighter weight brown piece to take it’s place.
this was a custom stamp I made for someone. i love it when I get to do cartoon characters. brings out the 6 year old in me.
That is awesome!!! It’s awesome to see the finished picture after seeing the work in progress. We will look for the brown vase at the state fair.
Welded (TIG) this up today. It has to go in a spot on a 1" thread-alet for a flow switch. It is a thermal dispersion flow switch. Yes they make adapters but time isn’t on our side.
This is the newest addition that I recently donated to the Dallas Makerspace Machine Shop. I converted a Sherline 4000 Lathe to Manual/CNC Operation. I designed and built the aluminum enclosure as seen in the photos. The enclosure contains the variable speed spindle motor power supply. The front panel Manual Pulse Generator (MPG) knob works similar to that on the Haas Mill and will incrementally move the X and Z axis. Internal circuitry consisting of eleven TTL logic gates generate all the required signals for the Stepper motor drivers. A simple toggle switch on the rear panel will convert the unit to full CNC control. The connection of the external computer with the CNC software is a future DMS project. This unit is located in the Machine Shop next to the other Sherline Lathe and Mill.
Rich, this is awesome!
I uploaded your photos to the wiki. I hope this is OK. I credited you with the construction, donation, and photos. I uploaded the photos so I could link to them from the Sherline Lathe wiki page (done). I also updated the photo on the Tools page with the one you posted.
I made a pendant out of a stamp that I found on the exchange shelf and had amazing kiln luck playing with glazes.
Really nice ones, I want to make some pendents and normall
I use stains and a reducing firing on them I like these better
I think I need to talk to you about them
I took Midnight Maker: Laser Advanced: Etching Tumblers & Glass on Rotary last night and with John Gorman’s help we managed to re-image and print out my personal logo on my cup with this awesome font he showed me earlier in the week! Thanks again John! It looks awesome!
