Dallas Maker -- Space Shuttle (Need Volunteers)
I am wanting to get some owners assigned to work on the Space Shuttle.
This is going to be a dynamic list and more people can be assigned to it than just one person.
General Cleaning – (Nobody Assigned)
Floor Repair – (Nobody Assigned)
Accessory Lights (Alex Rhodes)
Fluid Changes (Luke + Allen)
Vacuum System Repair (Robert + I need Help!)
Sound System (Nobody Assigned)
Window Repair (Nobody Assigned)
Vinyl Quote (Nobody Assigned)
More will likely be added as we move forward.
Does anyone know where to find replacement parts for the following ( I have no idea what it is other than it’s connected to the brake and vacuum lines.
Brake Booster (Also need to find the replacement parts)
I think Alex was looking into the floor as well as the lights. The engine might need the glow plugs checked out. The controller cycled on and off rapidly which indicates one of the plugs has gone bad. I’m new to diesel though so another opinion would be good!
How much of the current floor needs to be removed?
The part under the rear window that’s busted. Water has gotten in and rotted the floor. It looks like one or two sheets of plywood.
Would just ripping whole floor out of back make it easier to work on brakes / remove some rust / paint frame rails?
Are the sides / walls connected to the flooring?
What’s the final plan for the bus once it’s repaired and running?
From what I can tell the floor is just sheets of plywood bolted to the frame. There is a small runner on each side but it seems like it can easily be removed.
Can you move this question to a different thread. (Moderator please remove/split this question off) This thread is focused on getting owners assigned to jobs.
Please explain what you mean by vinyl quote. …vinyl like automotive interior and/or seat or dash or door panel upholstery work, or vinyl like wrapping/decals?
Sure Bitta!
This ultimately is logoing it could be the logos for the outside, inside, sponsor logos etc.
Ideally this person has experience on the vinyl cutter to give us adequate cost for such logos.
I was not considering the vinyl on dash. (If someone wants to take dash/seats/upholstery that sounds great but I am not sure it will be needed till the later part of the project)
