Since it can be cut with a cricut, it can possibly be cut with our vinyl cutter as well (basically a big cricut) if the material is large enough to be held in the machine.
Our Vinyl cutter is currently set up and calibrated for Vinyl stickers. I’m sure that it WILL work, but I’ve been told that we will not be adjusting the machine to deal with other types of materials. There is another vinyl cutter available at the space, but attempts to get it running have been unsuccessful. The plan would be that one of the two would be for standard vinyl stickers and the other for experimentation.
The rubber is required to repel the media particles. I remember a friend (ages ago) used to do intricate designs on and in glass with media blasting - he used some sort of liquid rubber and would carve his designs in it once is was semi solid.
I cut stencil blanks on my Cricut. BUT that kind of cutter vs the big vinyl cutter at DMS has the ability to do multiple passes of the same cut for some of the thicker materials. DMS has a Cameo that could do it if we get it hacked so we don’t have to pay for the proprietary design software for it. For sandblasting glass though, you can do single use vinyl cuts on the big vinyl cutter and that process works great for either sandblasting of chemical etching glass.
lol…yeah, I paid through the nose years ago to have some custom cut mats for some southwest prints we were framing w/ double mats. I had NO idea back then about CNC and how any of that worked, let alone that one day I’d have access to CNC equipment.
It was on the top shelf of the committee cabinet last I saw it. We took it out of the box to conserve space. We put it in there since we don’t have the Silhouette design studio license subscription which we need to run it unless we can get it hacked. The only other option I know of is to buy a copy of the Sure-Cuts-A-Lot software (about $60) so we can import fonts and .svg files into it for cutting.
It does have all the cords and mats and stuff, but came with no software.
