Are there any issues with using the Multicam to cut melamine board such as this:
I need to cut out some large circles and that seems like the best way to do it.
Nope, @rablack97 is the man if you need tips
Great. Thanks a lot.
Melamine cuts just fine using the dms feeds and speeds for softwoods/mdf
Yep. It worked very well.
However I did the first piece then while setting up for the first piece I noticed Iām not connected to the job server anymore (computer with red slash in bottom right hand corner of screen). Anyone know how I can reconnect?
I accidentally hit the emergency stop button and had to reset which is likely causing the issue.
edit I went through the shutdown and power up procedure and it works now.
