Hi, just wanted let yall know I messed up a cut path on the multicam so I ended up plunging about a half inch or so into the spoil board with a 3/8 inch endmill.
I patched it but there is a lot in there so it will take a while to dry. It also bowed in a bit since it first applied it, so a second coat might be in order.
I’ll be back at 10am ish to finish up the repair, so in the mean time avoid section 4.
Thanks
Adrian
