Hey all,
I’m in need of a rather obscure fastener because of it’s short thread length, and longer sleeve.
This is about as close as I can find: McMaster-Carr
The problem seems to be ones I’ve had supplied appear to be turned down from a fully threaded screw – I suspect it might be a special order part. See the below example:
A couple of questions for the hive mind:
- Does anyone have a recommendation for a similar fastener? Most important attributes are dimensions.
- If no part is available, are there any shops or manufactures one might turn to to run 5000 pieces?
Thanks for your suggestions!
