I am not fully done with it but it’s usable. It took me several tries but it is now set up to be 90* within .001 of an inch.
I also sharpened all the chisels at the space (except one I found after I put everything away ). Please do not use the chisels on anything but wood. Some had deep nicks in them, so if you aren’t sure which chisel to use, use the craftsman ones.
Thanks for the shout out,
I will return the shout out to you @AlexRhodes for following through and doing all the hard work and finishing the sharpening. Enjoyed the process and conversation.
