Computers in DM room
Should we ever be given the opportunity to spread out a bit, I hope we can come up with an arrangement that moves the two photo/video editing computers away from the filming equipment. Lots of attempts in the last couple of weeks to use one of those machines. Machine was free, but the room was not.
Just sharing a wish-list item. If anyone has an idea that would let it happen without the miracle of a Room of Requirement, please advise.
By my understanding, the computer in the digital media room is mobile and able to be moved and used outside of the room. That doesn’t solve the issue if the people filming don’t want you to enter the room to remove it, but it helps a bit in other cases.
There are three in there. The one attached to the 3-D scanner is mobile, but the other two are quite set in place. Your idea is likely my solution, though, and I thank you for it. My inventory shows it’s an i5 with 16 GB of RAM and a full Adobe CC 2015 licensed to it. So, as long as no one needs the 3D scanner, if I grab the cart during a break, I can use one of the machines. :slight_smile:
This is why I ask questions. Thanks again.
I didn’t even realize there were more computers in there (yesterday was my first time even using that room, for the 3D Scanner class). I’m quite surprised at how little use that device gets.
By the way, If anybody is on the fence about whether you want to take the 3D Scanner class or not, I highly recommend it. It was clear, concise, and thorough. It’s obvious that the teacher put a lot of effort into preparing everything.
