I am a bit unsure of where I am posting this. I am looking for an expert cad operator for some work I need done. I do not have much money so project interest is necessary, not to say you would not be paided for your services. Please let me know if anyone can help out. Thank you for your time and consideration in this matter.
Can you give some indication of the scope of the project or maybe the kind of project? This is pretty vague.
Mr. Olson,
I have an assembly file that is broke and needs to be fixed, I have not
been able to identify what’s wrong with the file itself. Once the file is
fixed then I need to add a model into the assembly. After the model is
added to the assembly I require the whole assembly glued together so that I
can rotate it as one without all the parts exploding off as they do now. I
also would like to make the whole assembly into a 3D printable file. Please
let me know if any of this makes sense. Thank you for your continued time
and consideration in these matters.
Truly,
Zac Glander
what software was the file created in
