Placed an antenna analyzer on the HF antenna this evening. The system is resonant… just not in any amateur bands.
I have disconnected the antenna and placed a sign on the rig noting that the station should not be used and the antenna is disconnected. @ke5bud is going to try to get on the roof and tack down the ladder line to see if this helps as the past few days have been the first significant winds we’ve seen.
Once that is done I will put the analyzer on and run the checks again. Good would be SWR under 3, Better would be under 2, and Best would be as close to 1 as possible. Yes, we have an antenna tuner. However, resolving the underlying problem will make the equipment last longer.
Below are a few graphs. One being the entire HF band. One for 20m and one for 80m.
https://drive.google.com/folderview?id=0ByomtnC1z9CtcXdlZF9SbTl1VWM&usp=sharing
