Collective Brainstorming - Dye Sub/Digital in CA
Lets brainstorm what we would like to see in the world of anything digital
Vinyl, Dye sub, printing, metaza act
PocketNC with case and tooling to make … small intricate things :wink: http://www.pocketnc.com/
HP Latex 335 Printer
Wide Format Printer with Contour Cutting:
Roland TrueVIS SG-540
“Whether you’re just starting out or wanting to expand production, new TrueVIS SG series printer/cutters offer all the quality and versatility of a Roland, at an unbeatable price. TrueVIS ushers in a new era of integrated printing and contour cutting, and the SG delivers the value you need to quickly and easily build your business.”
Can we put the Shapeki and vinyl cutter and any other noisy tool in the small room
The Shapeoko is slated to go into the Woodshop as part of the expansion.
A bypass tray for the dye sub printer, and a 3D vacuum press.
Shapeoko 3 XXL with touch probe and dust management.
I’m not sure where this falls into the mix, but I would really like to have a dedicated space for the silhouette cameo, even if its just space on a shelf where users can bring it out as they need it. It and its accessories getting moved here and there and everywhere makes things likely to get lost and/or broken.
Any Shapeoko larger than the small one won’t easily fit through a single doorway.
CA expansion meeting will be on the 28th 6:00 I’ve moved it to the Purple classroom so Dye Sub can setup @CaryF300
Hopefully will see you guys.
Can you get a price on both.
The bypass tray is $208 from most sources, but $169 if I get it from JDS Industries.
The 3D vacuum press is $1,399 on Sublimation101’s web site, but we can probably get it cheaper at the ISS Show in Fort Worth at the end of September, or at least get free shipping.
