Is the cold saw working at this time?? planning a project and need to know if it works and how do I become blessed to use it???
If functional I’ll provide a spot train. Last I saw it had a hydraulic leak so it was operating but not at capacity.
EDIT: just told it’s been fixed
I can’t cut 1/8 wall tube with this can I?
It will do solid mild steel, and up to 1/8" wall tubing stainless
I just dropped off a blade for sharpening, and will see about getting the rest done today. The saw needs to have the hydraulics bled and refilled. I would proceed with caution, the current blade is barely adequate.
What is the statue of the cold saw now? I had training on it a long time ago and could use a refresher… Is anyone available?
-Matthew
As of Friday Afternoon the floor guys were using the power for their equipment. We did put a refreshed blade on it.
It’s still powerless
Any clue on when it will be up again?
What else do we have that I can cut 1/8" 2" X 2" square tube?
the Horizontal Bandsaw in the metal shop will cut that fine.
Make sure you check for square. Last I checked, it had serious issues keeping a cut 90°.
Maybe it was just me.
Hi, any update on the Cold saw? Is it up and working again?
yeah it’s operational. Just a little slower since it needs some love, but working.
Good news… is it safe to assume the lock is still the pattern from a year ago?
Should be.
It was yesterday
