One of the clamp feet was tightened in the path of the blade. The padlock was not locked. The coolant doesn’t appear to be circulating. I think it’s down for maintenance.
Nope. It’s in working order. I just forgot to lock it back up last night. Also the jaws are adjustable for cutting miters. I had them offset to cut at an angle. I moved the head back to 0 degrees but I forgot to move the jaws back. Always check the jaws and adjust before you cut.
