CNC Router Operators
I just installed interlock 2.0 on the CNC Router and will do some testing this week. The only strange thing for the operator is on the very first use you will need to badge twice. It will be a one time thing to validate.
Improvements from 1.0
Response time should be sub 1 second.
Offline support
N+2 redundancy
Significantly better UX for admins
Operations
LED is red for off
LED is green for on
LED Blinks Red and Greed is access denied
If you should have access and you are getting access denied please let me or infastructure know as likely you have not been set to the correct group or your badge is not correct in our directory.
If for whatever reason it’s broken and myself or others don’t respond unpluging it will disengage the lock but please don’t do this unless it’s absolutely necesssary as I am tracking every disconnection.
Just a little bit of an update I have seen some people trying it and getting access denied.
Please make sure you are in the “Woodshop Multicam CNC Router” user group there are standalone terminals in the front room where you can scan your badge to confirm you are in the correct security group.
