CNC Router - Heads up users
I was doing some testing tonight with the new Diamond drag bit, and forgot to turn the spindle back on.
To re-enable, hit the menu button on the fob, downarrow to “Utility”, select "No_spin: and disable it. This will return the router to normal operation.
Please pass this along to anyone you see setting up to use the router.
Sorry for the old guy moment :frowning:
Does this mean we are going to open up use of the CNC router for engraving non-wood materials?
That is currently being considered, yes. We definitely plan to allow plastics for thos having taken the advanced CNC class, and the current testing is to determine the effect of allowing the full range of materials for the diamond drag (only). Again, will require the advanced CNC class, and will be strictly enforced.
