Here are some data to digest regarding classes and classrooms.
I can’t tell you whether we have enough classes, but I can tell you how many we have. I can tell you we either don’t have enough classrooms or we need to consider how we use them.
Background information about the data:
(1) Pulled from the “new” Calendar system (thanks @AlexRhodes!)
(2) Only actual data from 8/1/2016 through 10/31/2017 are included - the “new” calendar should have been stable by then and this also will EXclude “projections”
(3) My primary analysis regards room availability and utilization. For the most part, I included all scheduled items - both completed and cancelled - in the analysis. (I called this item BOOKINGS). If a room is booked, even if the class/event is later cancelled, that room isn’t available for any other classes/events so this impacts availability.
(4) Rejected bookings are all excluded.
(5) I won’t guarantee that each line item is correct. As I perused the 9000(ish) lines of data I see some things which are suspect. So - the big picture is accurate but the fine digits of accuracy are questionable.
(6) Lots of what we’d probably like to know can’t be extracted automatically. Feel free to do a manual compilation of the data if you’re so inclined.
Topic 1. Class costs
2134 classes in the time period. 78% of Classes had zero fees on the Calendar system. This should be adjusted down by 2% (see the footnotes on the graph). 89% of our classes had fees of $5 or less.
(EDIT: Reloaded graph which had an error in one data label).
Topic 2. Classes vs. Membership
Hours of classes have increased over time. So has membership. The data show a high statistical correlation (R2=0.74 & 0.78).
Topic 3. Classes vs. Events
As class hours have increased, event hours have decreased. There was a notable shift in composition around May 2017. Since that time period, events comprise an average of 28% of the scheduled times.
Topic 4. Cancellations vs. Completions
About 15% of the classes and events that schedule are later cancelled. Can’t analyze how timely the cancellations are … but last minute cancellations mean that a valuable room could go empty.
Topic 5. Classroom Availability
I analyzed only the four general-use classrooms: Conference Room, Interactive Classroom, Lecture Hall, and Purple Classroom. I included both classes and events. Here are data for the 15 month period (average), and also for the most recent month (October 2017). There are some time periods where utilization is >100%. This means that there was a cancellation and a rebooking; driving the scheduled hours above 100%.
The rooms are all busy. The October one month snapshot shows that at the current class and event load all the rooms are close to fully booked during prime time - not a lot of excess capacity.
Fifteen month Average
Current month Snapshot
