I need to run the bath sonicator for 40 hrs in one step of a process to make high-sensitivity graphene-infused rubber band strain sensors. If a graphene dispersion becomes too hot while in the bath sonicator, the dispersion is no good for later processing; hence, I need to setup a chilled water recirculating system around the bath sonicator.
I was thinking of printing two peristaltic pumps (see link below) and having them driven by the same motor. One pump for chilled water into the bath, one pump for warmed water out of the bath. I think in the end they probably will not be powerful enough for the volume of the bath or might pump at inconsistent rates. Anybody with suggestions or equipment?
