Cheap HAM radio
Probably a piece of crap, but very cheap
FYI, my experience with Baofeng is that they aren’t sensitive enough to receive APRS unless they have a different antenna/counterpoise/high vantage point.
The Baofengs are probably the most common HT’s in use by HAMs today. They work pretty well. No HT with a rubber ducky antenna picks up APRS very well, even the Kenwood TH-D72.
Those short stubby antennas have a naturally short range, but the front end of the various Baofengs are surprisingly good considering how ceap they are. And cheap is a good thing for a radio that is intended to be carried around.
AF5WH
By the way, they are availble cheaper from amazon
http://www.amazon.com/Baofeng-Transceiver-Warranty-Dual-Band-Radio/dp/B00KDRV91E?ie=UTF8&keywords=baofeng&qid=1464698564&ref_=sr_1_10&s=electronics&sr=1-10
In practice there isn’t really any difference between 5w and 8w with those stubby antennas. They are good enough to hit a repeater up to 10-15 miles.
They are cheap, but unless they vastly improved the interface they are very cumbersome to program for your favorite repeaters.
Yes, programming directly with the radio is a hassle; however, a $10 cable and an open source software package solves that problem.
http://chirp.danplanet.com/projects/chirp/wiki/Home
I’ve programmed a few of the 5 watt. I used chirp & it’s pretty straight forward unless you copying radios & have different software versions in the radios.
