I went over to the electronics lab last night and couldn’t find anything dumb enough looking for me to use to check resistance.
It could be that I need to learn more, or that I just need to bring my own $7 device with me, or that these things go missing all the time, or something else.
Snag me if you see me and I’ll walk you through it in a few minutes. I’ll be around this evening and tomorrow afternoon. I’m usually wearing one of these:
Or come by electronics office hours - next on June 12:
The $7 Harbor Fright (love that) multimeters are better than a wet finger, but not by much. They can work, but have a nomber of conditions where they misleading in substantial ways. I have a bunch of them from when they were periodic freebies. They’ve cost me a lot. I now use them only for really basic electronics classes where we compare them against a good one. .
Some long while back - prior to moving ELab over to 102 side - HF was giving them away. Show up w/ coupon whatever and here’s your free meter. 3 of those fine things showed up in the ELab. Connected to the same source and got 3 different readings. Shorted the leads and none displayed “0”. Where’s the trash can…
Had the exact same experience. Typically the probes would just disconnect themselves from the actual wire. I end up losing multimeters before I break them. I make an annual amazon order of 5 with decent reviews under $10. Went with these this year. It’s almost cheaper just to throw it away when the battery dies than to buy a pack of 9 volts.
That’s essentially the same as the HF electrically. It may be more mechanically robust. Battery state is a major weakness. If they aren’t very new your measurements may vary. A lot.
Thanks for the offers - I’ll take you up on help at some date in the future - busy moving house right now (but not busy enough so that i can’t post equipment demands, obvs)
I appreciate the education I’m getting.
Still, I do love those little meters, as before today I didn’t know that they couldn’t be trusted much.
I loathe 9v batteries intensely - expensive, short lifespans, low capacity, low power delivery - and do wish manufacturers would stop designing around them.
I may be cheaper to throw them away well before the battery dies. They get really squirrelly a few hundred millivolts off of peak charge, and many fail with no obvious symptoms - just wrong readings.
