I was wondering if anyone had a quick guide or some steps to programming a small chamfer on the CNC router through VCarve Pro. I want to move to Fusion 360 but still need to program all the tools and am a little confused about feeds and speeds.
You can do a profile cut with a V-Groove bit to cut a chamfer. Mess around with how deep and if you want the profile on the line or outside the line, use your preview to see if you like it. It should be pretty easy to program in, you can use the same edge line for your full cut-through profile.
DMS MultiCAM tools file
https://drive.google.com/open?id=1xVFmfoaNemsYVAqk-H7l5LPbP3yz4MXl
Credit to @fedakkee
Man, that is amazing. Now my workflow will be much better.
