Please follow this thread to determine if your items are ready for pick up. Please pickup your piece(s) ASAP.
If your piece has a star in it, the item is being marked for our 30-day guideline. Please put the stars back in the glass dish on the shelf after collecting your piece(s).
As a reminder there is no personal storage on our shelves or in the Ceramics space, that means bisque items should not be on the In Progress shelves. Please be mindful of other community members and use a ware board that fit the size of your piece, this will allow more room for makers to make.
If you have a piece that’s been “missing”, please double check the Needs Attention thread and shelf. Your piece will have a note attached as to why the kiln team did/can not fire, it is important that you fix the issue in order for your piece to be fired. Continuing to place your item on the shelf for firing without fixing the issue will not result in an ultimate firing of your piece.
If you need assistance or other options to achieve your desired results, please consult the wiki guidelines for firing or reach out to the community for further information.
Thank you!
