Center and chuck combo?
I’ve come across this twice in the last week. I’ve yet to see anyone use it like this, do I not know some neat lathe trick or should do someone get a better explanation on using chucks?
I also undid that little combo on Sunday right before my class. There is approximately zero reason for that. That same lathe hadn’t been swept/vacuumed after use either.
I used the Woodshop Sunday night.
There is a weak muscle about cleaning up.
I think what would be perfect would be a room sized vacuum. As you left the room, you would throw a switch and all the sawdust would be sucked up by a giant room sized vacuum. No small tools would be safe.
Probably only cost us… $1 millllllllion dollars.
Which is sad because it takes maybe 1-2 minutes to sweep up after yourself.
I’d throw in a fiver for that room vac.
I think if you stayed in the room it would Hoover your pocket change and ear wax too.
Better to vacuum out the folks who consistently leave messes.
A swarm of roombas!
I do not know either.
I wish it only took me a minute or two to clean up, but then, usually, I’m cleaning up after considerably more than myself in the woodshop.
One thing I have noticed, with considerable regularity, are folks working in some other area, come into the woodshop, use a tool (bandsaw, drillpress, etc) and then leave without cleaning up. It’s probably easy to move over to a tool, see a mess already there, and think ‘screw this, I’m not picking up some pig’s mess.’ I know there’s the whole ‘do-ocracy’ thing, but how prevalent is it?
Also, whoever left a toolbox top full of chisels there Saturday night, I put them back for you…
You’re welcome.
Maybe someone confusing it for a chuck screw?
That was my first inclination as well.
Read that as “wombats” until I put my 'puter glasses on.
