Today a fellow member and came in early to laser cut some Radio Controlled plans from Dollar Tree $1 foam. We have previously cut many sheets of foam on the lasers. One of them was un-serviceable and another was occupied so we had to use the NEW laser. Does it have a name? (The one in the middle).
We used some of the same settings we used previously and the foam caught fire. We extinguished the fire and reset the setting to much lower settings. The cut still caught fire.
We then changed the settings to very low settings (15% at 250mm) and the cuts were insufficient to cut entirely through the foam. I presume we could lower the settings further and cut multiple times, but this extends the amount of time on the laser and makes each cut more time consuming.
Any suggestions?
